ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / Contains Method
The base geometry.
The comparison geometry.
Example
    Contains Method (IGeometryEngine)
    Returns true if geometry1 contains geometry2.
    Syntax
    Function Contains( _
       ByVal geometry1 As Geometry, _
       ByVal geometry2 As Geometry _
    ) As Boolean
    Parameters
    geometry1
    The base geometry.
    geometry2
    Return Value
    True if the geometry1 contains geometry2.
    Exceptions
    ExceptionDescription
    Either geometry1 or geometry2 or both are null.
    The method is not implemented for GeometryBag.
    Incompatible spatial references between the input geometries.
    Remarks
    If both geometry1 and geometry2 are not empty, then geometry1 contains geometry2 if the intersection of their interiors is not empty and geometry2 is a subset of geometry1.
    If geometry1 is empty, then it does not contain geometry2.
    If geometry1 is not empty and geometry2 is empty, then geometry1 contains geometry2.
    Contains is the opposite of Within. That is, geometry1 contains geometry2 if and only if geometry2 is within geometry1.
    GeometryEngine Contains
    Example
    Polygon contains MapPoints, Polylines, Polygons
        // build a polygon
        List<MapPoint> pts =
          MapPointBuilderEx.CreateMapPoint(1.0, 1.0),
      MapPointBuilderEx.CreateMapPoint(1.0, 2.0),
      MapPointBuilderEx.CreateMapPoint(2.0, 2.0),
      MapPointBuilderEx.CreateMapPoint(2.0, 1.0),
        Polygon poly = PolygonBuilderEx.CreatePolygon(pts);
        // test if an inner point is contained
        MapPoint innerPt = MapPointBuilderEx.CreateMapPoint(1.5, 1.5);
        bool contains = GeometryEngine.Instance.Contains(poly, innerPt);   // contains = true
        // test a point on a boundary
        contains = GeometryEngine.Instance.Contains(poly, poly.Points[0]);     // contains = false
        // test an interior line
        MapPoint innerPt2 = MapPointBuilderEx.CreateMapPoint(1.25, 1.75);
        List<MapPoint> innerLinePts = [innerPt, innerPt2];
        // test an inner polyline
        polyline = PolylineBuilderEx.CreatePolyline(innerLinePts);
        contains = GeometryEngine.Instance.Contains(poly, polyline);   // contains = true
        // test a line that crosses the boundary
        MapPoint outerPt = MapPointBuilderEx.CreateMapPoint(3, 1.5);
        List<MapPoint> crossingLinePts = [innerPt, outerPt];
        polyline = PolylineBuilderEx.CreatePolyline(crossingLinePts);
        contains = GeometryEngine.Instance.Contains(poly, polyline);     // contains = false
        // test a polygon in polygon
        Envelope env = EnvelopeBuilderEx.CreateEnvelope(innerPt, innerPt2);
        contains = GeometryEngine.Instance.Contains(poly, env);      // contains = true
    Requirements
