ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / Difference Method
the Geometry instance on the left hand side of the subtraction.
the Geometry on the right hand side being subtracted.
Example
    Difference Method (IGeometryEngine)
    Performs the topological difference operation on the two geometries.
    Syntax
    Function Difference( _
       ByVal geometry1 As Geometry, _
       ByVal geometry2 As Geometry _
    ) As Geometry
    Parameters
    geometry1
    geometry2
    Return Value
    Returns the result of subtraction. The result has the dimension of geometry1 If either of the input geometries are empty, then geometry1 is returned unchanged.
    Exceptions
    ExceptionDescription
    Either geometry1 or geometry2 or both are null or empty.
    The method is not implemented for GeometryBag.
    Incompatible spatial references between the input geometries.
    Remarks
    GeometryEngine Difference
    Example
    Difference between two Polygons
        List<MapPoint> polyPts =
          MapPointBuilderEx.CreateMapPoint(3.0, 2.0),
      MapPointBuilderEx.CreateMapPoint(3.0, 6.0),
      MapPointBuilderEx.CreateMapPoint(6.0, 6.0),
      MapPointBuilderEx.CreateMapPoint(6.0, 2.0),
        Polygon poly1 = PolygonBuilderEx.CreatePolygon(polyPts);
        Envelope env = EnvelopeBuilderEx.CreateEnvelope(MapPointBuilderEx.CreateMapPoint(1.0, 1.0), MapPointBuilderEx.CreateMapPoint(4, 4));
        Polygon poly2 = PolygonBuilderEx.CreatePolygon(env);
        Geometry result = GeometryEngine.Instance.Difference(poly1, poly2);
        Polygon polyResult = result as Polygon;
        // polyResult.Area = 10.0
        result = GeometryEngine.Instance.Difference(poly2, poly1);
        // polyResult.Area = 7.0
    Requirements
