Parameters
- geometry1
- The base geometry.
- geometry2
- The comparison geometry.
Return Value
True if the geometry1 and geometry2 are disjoint.
| Exception | Description |
| System.ArgumentNullException | Either geometry1 or geometry2 or both are null. |
| System.NotImplementedException | The method is not implemented for GeometryBag. |
| System.InvalidOperationException | Incompatible spatial references between the input geometries. |
| System.InvalidOperationException | Either geometry1 or geometry2 is not Z-Aware. |
// pt on pt
MapPoint pt = MapPointBuilderEx.CreateMapPoint(1.0, 1.0);
MapPoint pt2 = MapPointBuilderEx.CreateMapPoint(2.0, 2.5);
bool disjoint = GeometryEngine.Instance.Disjoint(pt, pt2); // result is true
MultipointBuilderEx mpb = new();
mpb.AddPoint(pt);
mpb.AddPoint(pt2);
Multipoint multiPoint = mpb.ToGeometry();
disjoint = GeometryEngine.Instance.Disjoint(multiPoint, pt); // result is false
// pt and line
List<MapPoint> list =
MapPointBuilderEx.CreateMapPoint(1.0, 1.0),
MapPointBuilderEx.CreateMapPoint(3.0, 3.0),
MapPointBuilderEx.CreateMapPoint(5.0, 1.0),
Polyline line1 = PolylineBuilderEx.CreatePolyline(list);
disjoint = GeometryEngine.Instance.Disjoint(line1, pt2); // result is true
disjoint = GeometryEngine.Instance.Disjoint(pt2, line1); // result is true
// end pt of line
disjoint = GeometryEngine.Instance.Disjoint(line1, pt); // result is false
// pt and polygon
List<MapPoint> polyPts =
MapPointBuilderEx.CreateMapPoint(3.0, 2.0),
MapPointBuilderEx.CreateMapPoint(3.0, 6.0),
MapPointBuilderEx.CreateMapPoint(6.0, 6.0),
MapPointBuilderEx.CreateMapPoint(6.0, 2.0),
Polygon poly1 = PolygonBuilderEx.CreatePolygon(polyPts);
disjoint = GeometryEngine.Instance.Disjoint(poly1, pt); // result is true
disjoint = GeometryEngine.Instance.Disjoint(pt, poly1); // result is true
// line and line
List<MapPoint> list2 =
MapPointBuilderEx.CreateMapPoint(1.0, 3.0),
MapPointBuilderEx.CreateMapPoint(3.0, 1.0),
MapPointBuilderEx.CreateMapPoint(5.0, 3.0),
Polyline line2 = PolylineBuilderEx.CreatePolyline(list2);
disjoint = GeometryEngine.Instance.Disjoint(line1, line2); // result is false
// line and polygon
disjoint = GeometryEngine.Instance.Disjoint(poly1, line1); // result is false
disjoint = GeometryEngine.Instance.Disjoint(line1, poly1); // result is false
// polygon and polygon
Envelope env = EnvelopeBuilderEx.CreateEnvelope(MapPointBuilderEx.CreateMapPoint(1.0, 1.0), MapPointBuilderEx.CreateMapPoint(4, 4));
Polygon poly2 = PolygonBuilderEx.CreatePolygon(env);
disjoint = GeometryEngine.Instance.Disjoint(poly1, poly2); // result is false
// disjoint3D
SpatialReference sr = SpatialReferences.WGS84;
MapPoint pt3D_1 = MapPointBuilderEx.CreateMapPoint(1, 1, 1, sr);
MapPoint pt3D_2 = MapPointBuilderEx.CreateMapPoint(2, 2, 2, sr);
MapPoint pt3D_3 = MapPointBuilderEx.CreateMapPoint(1, 1, 2, sr);
MultipointBuilderEx mpbEx = new();
mpbEx.AddPoint(pt3D_1);
mpbEx.AddPoint(pt3D_2);
mpbEx.HasZ = true;
multiPoint = mpbEx.ToGeometry();
disjoint = GeometryEngine.Instance.Disjoint3D(multiPoint, pt3D_2); // disjoint = false
disjoint = GeometryEngine.Instance.Disjoint3D(multiPoint, pt3D_3); // disjoint = true
