ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / GeodesicBuffer Method / GeodesicBuffer(Geometry,Double) Method
The input geometry. Cannot be null and its spatial reference cannot be null.
The distance (in meters) to buffer the geometry.
Example
    Creates a buffer polygon at the specified geodesic distance around the given geometry.
    Syntax
    Overloads Function GeodesicBuffer( _
       ByVal geometry As Geometry, _
       ByVal distance As Double _
    ) As Geometry
    Parameters
    geometry
    distance
    Return Value
    A geometry representing the buffered area. If the input geometry is empty, then an empty polygon is returned.
    Exceptions
    ExceptionDescription
    Geometry is null or geometry's spatial reference is null.
    The method is not implemented for GeometryBag.
    The method is not implemented for Multipatch.
    The buffer distance must be a valid floating point number.
    Spatial reference of geometryis an image coordinate system.
    Remarks
    Geodesic distance is the shortest distance between two points on the surface of the Earth.
    If the buffer distance is zero and the input geometry is a polygon or an envelope, then a polygon created from the input geometry is returned.
    If the distance is less than or equal to zero and the input geometry is not a polygon or an envelope, then an empty polygon is returned.
    Example
    Create a buffer polygon at the specified geodesic distance
        // buffer a point
        MapPoint pt = MapPointBuilderEx.CreateMapPoint(1.0, 1.0, SpatialReferences.WGS84);
        Polygon outPolygon = GeometryEngine.Instance.GeodesicBuffer(pt, 5) as Polygon;
        double delta = SpatialReferences.WGS84.XYTolerance * 2 * Math.Sqrt(2);
        ReadOnlyPointCollection points = outPolygon.Points;
        foreach (MapPoint p in points)
          double d = GeometryEngine.Instance.GeodesicDistance(pt, p);
          // d = 5 (+- delta)
        // specify a unit for the distance
        outPolygon = GeometryEngine.Instance.GeodesicBuffer(pt, 5000, LinearUnit.Millimeters) as Polygon;
        // buffer of 0 distance produces an empty geometry
        Geometry g = GeometryEngine.Instance.GeodesicBuffer(pt, 0);
        // g.IsEmpty = true
        // buffer many points
        List<MapPoint> list =
          MapPointBuilderEx.CreateMapPoint(1.0, 1.0, SpatialReferences.WGS84),
      MapPointBuilderEx.CreateMapPoint(10.0, 20.0),
      MapPointBuilderEx.CreateMapPoint(40.0, 40.0),
      MapPointBuilderEx.CreateMapPoint(60.0, 60.0),
        outPolygon = GeometryEngine.Instance.GeodesicBuffer(list, 10000) as Polygon;
        // outPolygon.PartCount = 4
        // buffer different geometry types
        List<Coordinate2D> coords =
          new Coordinate2D(1, 2), new Coordinate2D(10, 20), new Coordinate2D(20, 30),
      new Coordinate2D(50, 60), new Coordinate2D(70, 80), new Coordinate2D(80, 40),
      new Coordinate2D(90, 10), new Coordinate2D(110, 15), new Coordinate2D(120, 30),
      new Coordinate2D(10, 40), new Coordinate2D(-10, 40), new Coordinate2D(-10, 50)
        List<Geometry> manyGeometries =
      PolylineBuilderEx.CreatePolyline([coords[0], coords[1], coords[2]], SpatialReferences.WGS84),
      PolylineBuilderEx.CreatePolyline([coords[3], coords[4], coords[5]]),
      PolygonBuilderEx.CreatePolygon([coords[9], coords[10], coords[11]])
        outPolygon = GeometryEngine.Instance.GeodesicBuffer(manyGeometries, 20000) as Polygon;
        // specify unit types
        outPolygon = GeometryEngine.Instance.GeodesicBuffer(manyGeometries, 20, LinearUnit.Miles) as Polygon;
    Requirements
