ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / GeodesicBuffer Method / GeodesicBuffer(IEnumerable<Geometry>,Double) Method
Specifies the input geometries.
The distance (in meters) to buffer the geometries.
Example
    Creates buffers at the specified distance around the given geometries. Will union the results of all buffers.
    Syntax
    Overloads Function GeodesicBuffer( _
       ByVal geometries As IEnumerable(Of Geometry), _
       ByVal distance As Double _
    ) As Geometry
    Parameters
    geometries
    distance
    Return Value
    The polygon that represents the buffered area.
    Exceptions
    ExceptionDescription
    Geometries is null or empty
    The method is not implemented for GeometryBag.
    Geometries have no spatial reference.
    The first non-null spatial reference is an image coordinate system.
    The buffer distance must be a valid floating point number.
    Remarks
    At least one geometry must have a spatial reference that is not null or Unknown. The spatial reference of the output geometries is the first valid spatial reference found in the list of geometries. All other geometries are projected to this spatial reference, if necessary. The returned polygon is the union of all the buffered geometries.
    If the buffer distance is zero and the input geometry is a polygon or an envelope, then a polygon is created from the input geometries.
    If the distance is less than or equal to zero and the input geometry is not a polygon or an envelope, then an empty polygon is created.
    Example
    Create a buffer polygon at the specified geodesic distance
        // buffer a point
        MapPoint pt = MapPointBuilderEx.CreateMapPoint(1.0, 1.0, SpatialReferences.WGS84);
        Polygon outPolygon = GeometryEngine.Instance.GeodesicBuffer(pt, 5) as Polygon;
        double delta = SpatialReferences.WGS84.XYTolerance * 2 * Math.Sqrt(2);
        ReadOnlyPointCollection points = outPolygon.Points;
        foreach (MapPoint p in points)
          double d = GeometryEngine.Instance.GeodesicDistance(pt, p);
          // d = 5 (+- delta)
        // specify a unit for the distance
        outPolygon = GeometryEngine.Instance.GeodesicBuffer(pt, 5000, LinearUnit.Millimeters) as Polygon;
        // buffer of 0 distance produces an empty geometry
        Geometry g = GeometryEngine.Instance.GeodesicBuffer(pt, 0);
        // g.IsEmpty = true
        // buffer many points
        List<MapPoint> list =
          MapPointBuilderEx.CreateMapPoint(1.0, 1.0, SpatialReferences.WGS84),
      MapPointBuilderEx.CreateMapPoint(10.0, 20.0),
      MapPointBuilderEx.CreateMapPoint(40.0, 40.0),
      MapPointBuilderEx.CreateMapPoint(60.0, 60.0),
        outPolygon = GeometryEngine.Instance.GeodesicBuffer(list, 10000) as Polygon;
        // outPolygon.PartCount = 4
        // buffer different geometry types
        List<Coordinate2D> coords =
          new Coordinate2D(1, 2), new Coordinate2D(10, 20), new Coordinate2D(20, 30),
      new Coordinate2D(50, 60), new Coordinate2D(70, 80), new Coordinate2D(80, 40),
      new Coordinate2D(90, 10), new Coordinate2D(110, 15), new Coordinate2D(120, 30),
      new Coordinate2D(10, 40), new Coordinate2D(-10, 40), new Coordinate2D(-10, 50)
        List<Geometry> manyGeometries =
      PolylineBuilderEx.CreatePolyline([coords[0], coords[1], coords[2]], SpatialReferences.WGS84),
      PolylineBuilderEx.CreatePolyline([coords[3], coords[4], coords[5]]),
      PolygonBuilderEx.CreatePolygon([coords[9], coords[10], coords[11]])
        outPolygon = GeometryEngine.Instance.GeodesicBuffer(manyGeometries, 20000) as Polygon;
        // specify unit types
        outPolygon = GeometryEngine.Instance.GeodesicBuffer(manyGeometries, 20, LinearUnit.Miles) as Polygon;
    Requirements
