Parameters
- geometry1
- The base geometry.
- geometry2
- The comparison geometry.
Return Value
True if the two geometries intersect.
| Exception | Description |
| System.ArgumentNullException | Either geometry1 or geometry2 or both are null. |
| System.NotImplementedException | The method is not implemented for GeometryBag. |
| System.InvalidOperationException | Incompatible spatial references between the input geometries. |
// determine intersection between two polylines
List<MapPoint> pts =
MapPointBuilderEx.CreateMapPoint(1.0, 1.0),
MapPointBuilderEx.CreateMapPoint(3.0, 3.0),
MapPointBuilderEx.CreateMapPoint(5.0, 1.0),
Polyline line1 = PolylineBuilderEx.CreatePolyline(pts);
List<MapPoint> pts2 =
MapPointBuilderEx.CreateMapPoint(1.0, 3.0),
MapPointBuilderEx.CreateMapPoint(3.0, 1.0),
MapPointBuilderEx.CreateMapPoint(5.0, 3.0),
Polyline line2 = PolylineBuilderEx.CreatePolyline(pts2);
bool intersects = GeometryEngine.Instance.Intersects(line1, line2); // intersects = true
Geometry g = GeometryEngine.Instance.Intersection(line1, line2, GeometryDimensionType.EsriGeometry0Dimension);
Multipoint resultMultipoint = g as Multipoint;
// result is a multiPoint that intersects at (2,2) and (4,2)
