ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / Move Method / Move(Geometry,Double,Double) Method
The geometry to move.
Units along the X-axis to move the geometry.
Units along the Y-axis to move the geometry.
Example
    Moves a geometry.
    Syntax
    Overloads Function Move( _
       ByVal geometry As Geometry, _
       ByVal dx As Double, _
       ByVal dy As Double _
    ) As Geometry
    Parameters
    geometry
    dx
    dy
    Return Value
    The moved geometry. If the input geometry is empty, then it is returned unchange.
    Exceptions
    ExceptionDescription
    Geometry is null.
    The method is not implemented for GeometryBag.
    Remarks
    Moves the Geometry along the X-axis and the Y-axis. Only changes the position of the Geometry without altering any of the other characteristics. Move is a spatial offset.
    GeometryEngine Move
    Example
    Move a MapPoint
      MapPoint pt = MapPointBuilderEx.CreateMapPoint(1.0, 3.0);
      MapPoint ptResult = GeometryEngine.Instance.Move(pt, -3.5, 2.5) as MapPoint;
      // ptResult is (-2.5, 5.5)
    Move a Polyline
        List<MapPoint> pts =
          MapPointBuilderEx.CreateMapPoint(1.0, 1.0, 3.0),
      MapPointBuilderEx.CreateMapPoint(3.0, 3.0, 3.0),
      MapPointBuilderEx.CreateMapPoint(3, 2, 3.0),
      MapPointBuilderEx.CreateMapPoint(4.0, 2.0, 3.0),
        polyline = PolylineBuilderEx.CreatePolyline(pts);
        Geometry geometry = GeometryEngine.Instance.Move(polyline, 3, 2);
        Polyline polylineResult = geometry as Polyline;
        // polylineResult.Points[0] = 4.0, 3.0, 3.0
        // polylineResult.Points[1] = 6.0, 5.0, 3.0
        // polylineResult.Points[2] = 6.0, 4.0, 3.0
        // polylineResult.Points[3] = 7.0, 4.0, 3.0
    Requirements
