ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / Move Method / Move(Geometry,Double,Double,Double) Method
The geometry to move.
Units along the X-axis to move the geometry.
Units along the Y-axis to move the geometry.
Units along the Z-axis to move the geometry.
Example
    Moves the geometry in a 3-dimensional manner.
    Syntax
    Overloads Function Move( _
       ByVal geometry As Geometry, _
       ByVal dx As Double, _
       ByVal dy As Double, _
       ByVal dz As Double _
    ) As Geometry
    Parameters
    geometry
    dx
    dy
    dz
    Return Value
    The moved geometry. If the input geometry is empty, then it is returned unchange.
    Exceptions
    ExceptionDescription
    Geometry is null.
    The method is not implemented for GeometryBag.
    This geometry is not Z-Aware.
    Spatial reference of geometryis an image coordinate system.
    Remarks
    Moves the geometry along the X-axis, the Y-axis and the Z-axis. The geometry must be Z-Aware or an exception will be thrown. Only changes the position of the Geometry without altering any of the other characteristics. Move is a spatial offset.
    GeometryEngine Move
    Example
    Move a z-aware MapPoint
      MapPoint zPt = MapPointBuilderEx.CreateMapPoint(1.0, 3.0, 2.0);
      MapPoint zPtResult = GeometryEngine.Instance.Move(zPt, 4, 0.25, 0.5) as MapPoint;
      // zPtResult is (5.0, 3.25, 2.5);
    Requirements
