ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / NearestPoint Method
The geometry.
The point to which the returned point will be nearest.
Example
    NearestPoint Method (IGeometryEngine)
    Finds the nearest point in the geometry to a specified point.
    Syntax
    Function NearestPoint( _
       ByVal geometry As Geometry, _
       ByVal point As MapPoint _
    ) As ProximityResult
    Parameters
    geometry
    The geometry.
    point
    Return Value
    ProximityResult.
    If the input geometry is a non-empty point, then ProximityResult.PointIndex = 0, ProximityResult.PartIndex = 0, and ProximityResult.SegmentIndex is null.
    If the input geometry is a non-empty multipoint, ProximityResult.PointIndex is the index of the nearest point in the Multipoint, ProximityResult.PartIndex = ProximityResult.PointIndex, and ProximityResult.SegmentIndex is null.
    Otherwise, if the input geometry is non-empty, then ProximityResult.PointIndex is null and ProximityResult.SegmentIndex is the segment which contains the nearest point. The segment index is relative to the ProximityResult.PartIndex. For example, if the segment index = 0 and the part index = 2, then the segment containing the nearest point is segment 0 of part 2. In other words, the segment is the first segment of the third part.
    ProximityResult.RightSide specifies if the input query point is on the right side of the input geometry or not.
    If either of the input geometries are empty, then ProximityResult.Distance = -1, ProximityResult.Point is empty, ProximityResult.RightSide = false, ProximityResult.PartIndex = -1, ProximityResult.PointIndex is null, and ProximityResult.SegmentIndex = null.
    Exceptions
    ExceptionDescription
    Either geometry or point or both are null.
    The method is not implemented for GeometryBag.
    This function is not implemented for envelopes.
    Remarks
    The nearest point does not have to be a vertex of the input geometry. It can be any point on the geometry. If the geometry is a Polygon, then the nearest point will be a point on the boundary of the Polygon.
    GeometryEngine NearestPoint
    Example
    Nearest Point versus Nearest Vertex
      SpatialReference sr = SpatialReferences.WGS84;
      MapPoint pt = MapPointBuilderEx.CreateMapPoint(5, 5, sr);
      List<Coordinate2D> coords =
        new Coordinate2D(10, 1),
      new Coordinate2D(10, -4),
      new Coordinate2D(0, -4),
      new Coordinate2D(0, 1),
      polygon = PolygonBuilderEx.CreatePolygon(coords);
      // find the nearest point in the polygon geometry to the pt
      ProximityResult result = GeometryEngine.Instance.NearestPoint(polygon, pt);
      // result.Point = 5, 1
      // result.SegmentIndex = 3
      // result.PartIndex = 0
      // result.PointIndex = null
      //result.Distance = 4
      //result.RightSide = false
      // find the nearest vertex in the polgyon geometry to the pt
      result = GeometryEngine.Instance.NearestVertex(polygon, pt);
      // result.Point = 10, 1
      // result.PointIndex = 0
      // result.SegmentIndex = null
      // result.Distance = Math.Sqrt(41)
      // result.RightSide = false
    Requirements
