ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / NearestVertex Method
The geometry.
The point to which the returned vertex will be nearest.
Example
    NearestVertex Method (IGeometryEngine)
    Finds the nearest vertex in the geometry to a specified point.
    Syntax
    Function NearestVertex( _
       ByVal geometry As Geometry, _
       ByVal point As MapPoint _
    ) As ProximityResult
    Parameters
    geometry
    The geometry.
    point
    Return Value
    ProximityResult.
    ProximityResult.PointIndex is the index of the nearest vertex.
    ProximityResult.SegmentIndex is null.
    ProximityResult.PartIndex is the index of the part containing the nearest vertex.
    Proximity.RightSide = false.
    If either of the input geometries are empty, then ProximityResult.Distance = -1, ProximityResult.Point is empty, ProximityResult.PartIndex = -1, ProximityResult.PointIndex is null, and ProximityResult.SegmentIndex = null.
    Exceptions
    ExceptionDescription
    Either geometry or point or both are null or empty.
    The method is not implemented for GeometryBag.
    Example
    Nearest Point versus Nearest Vertex
      SpatialReference sr = SpatialReferences.WGS84;
      MapPoint pt = MapPointBuilderEx.CreateMapPoint(5, 5, sr);
      List<Coordinate2D> coords =
        new Coordinate2D(10, 1),
      new Coordinate2D(10, -4),
      new Coordinate2D(0, -4),
      new Coordinate2D(0, 1),
      polygon = PolygonBuilderEx.CreatePolygon(coords);
      // find the nearest point in the polygon geometry to the pt
      ProximityResult result = GeometryEngine.Instance.NearestPoint(polygon, pt);
      // result.Point = 5, 1
      // result.SegmentIndex = 3
      // result.PartIndex = 0
      // result.PointIndex = null
      //result.Distance = 4
      //result.RightSide = false
      // find the nearest vertex in the polgyon geometry to the pt
      result = GeometryEngine.Instance.NearestVertex(polygon, pt);
      // result.Point = 10, 1
      // result.PointIndex = 0
      // result.SegmentIndex = null
      // result.Distance = Math.Sqrt(41)
      // result.RightSide = false
    Requirements
