ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / NormalizeCentralMeridian Method
The geometry that you want folded. If the input geometry is empty, then it is returned unchanged.
    NormalizeCentralMeridian Method (IGeometryEngine)
    Folds the geometry into a range of 360 degrees. This may be necessary when wrap around is enabled on the map. If geometry is an Envelope then a Polygon will be returned unless the Envelope is empty in which case an empty Envelope will be returned.
    Syntax
    Function NormalizeCentralMeridian( _
       ByVal geometry As Geometry _
    ) As Geometry
    Geometry NormalizeCentralMeridian(
       Geometry geometry
    Parameters
    geometry
    Return Value
    The folded geometry.
    Exceptions
    ExceptionDescription
    Geometry is null.
    The method is not implemented for GeometryBag or Multipatch.
    Geometry.SpatialReference is null.
    Requirements
