ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / Relate Method
The first geometry in the relation.
The second geometry in the relation.
The DE-9IM matrix relation encoded as a string.
Example
    Relate Method (IGeometryEngine)
    Performs custom relational operations between two geometries using a Dimensionally Extended Nine-Intersection Model, DE-9IM, formatted string.
    Syntax
    Parameters
    geometry1
    geometry2
    relateString
    Return Value
    Returns true if the relation holds, false otherwise.
    Exceptions
    ExceptionDescription
    Either geometry1 or geometry2 or both are null.
    The method is not implemented for GeometryBag or Multipatch.
    Incompatible spatial references between the input geometries.
    Invalid relate string or the string is null.
    Spatial reference of geometry1or geometry2is an image coordinate system.
    Remarks
    The DE-9IM is a standard used to describe spatial relationships between two geometries and can be referenced at https://en.wikipedia.org/wiki/DE-9IM. For examples of how to apply the DE-9IM, see the Relate and the Dimensionally Extended Nine-Intersection Model (DE 9IM) Pro Concepts topic .
    Examples of how to use the Relate method can be found at the Pro Guide for Relational Operations. All of the predefined relational operations can be defined (including Intersect, Within, Contains, Crosses, Disjoint, Overlaps, Equals and Touches).
    Example
    Determine relationship between two geometries
      // set up some geometries
      // points
      MapPoint point0 = MapPointBuilderEx.CreateMapPoint(0, 0, SpatialReferences.WGS84);
      MapPoint point1 = MapPointBuilderEx.CreateMapPoint(1, 1, SpatialReferences.WGS84);
      MapPoint point2 = MapPointBuilderEx.CreateMapPoint(-5, 5, SpatialReferences.WGS84);
      // multipoint
      List<MapPoint> points = [point0, point1, point2];
      Multipoint multipoint = MultipointBuilderEx.CreateMultipoint(points, SpatialReferences.WGS84);
      // polygon
      List<Coordinate2D> polygonCoords =
          new Coordinate2D(-10, 0),
      new Coordinate2D(0, 10),
      new Coordinate2D(10, 0),
      polygon = PolygonBuilderEx.CreatePolygon(polygonCoords, SpatialReferences.WGS84);
      // polylines
      Polyline polyline1 = PolylineBuilderEx.CreatePolyline(LineBuilderEx.CreateLineSegment(new Coordinate2D(-9.1, 0.1), new Coordinate2D(0, 9)), SpatialReferences.WGS84);
      Polyline polyline2 = PolylineBuilderEx.CreatePolyline(LineBuilderEx.CreateLineSegment(new Coordinate2D(-5, 5), new Coordinate2D(0, 5)), SpatialReferences.WGS84);
      Polyline polyline3 = PolylineBuilderEx.CreatePolyline(LineBuilderEx.CreateLineSegment(new Coordinate2D(2.09, -2.04), new Coordinate2D(5, 10)), SpatialReferences.WGS84);
      Polyline polyline4 = PolylineBuilderEx.CreatePolyline(LineBuilderEx.CreateLineSegment(new Coordinate2D(10, -5), new Coordinate2D(10, 5)), SpatialReferences.WGS84);
      List<Segment> segments =
          LineBuilderEx.CreateLineSegment(new Coordinate2D(5.05, -2.87), new Coordinate2D(6.35, 1.57)),
      LineBuilderEx.CreateLineSegment(new Coordinate2D(6.35, 1.57), new Coordinate2D(4.13, 2.59)),
      LineBuilderEx.CreateLineSegment(new Coordinate2D(4.13, 2.59), new Coordinate2D(5, 5))
      Polyline polyline5 = PolylineBuilderEx.CreatePolyline(segments, SpatialReferences.WGS84);
      segments.Add(LineBuilderEx.CreateLineSegment(new Coordinate2D(5, 5), new Coordinate2D(10, 10)));
      Polyline polyline6 = PolylineBuilderEx.CreatePolyline(segments, SpatialReferences.WGS84);
      Polyline polyline7 = PolylineBuilderEx.CreatePolyline(polyline5);
      Polyline polyline8 = PolylineBuilderEx.CreatePolyline(LineBuilderEx.CreateLineSegment(new Coordinate2D(5, 5), new Coordinate2D(10, 10)), SpatialReferences.WGS84);
      segments.Clear();
      segments.Add(LineBuilderEx.CreateLineSegment(new Coordinate2D(0.6, 3.5), new Coordinate2D(0.7, 7)));
      segments.Add(LineBuilderEx.CreateLineSegment(new Coordinate2D(0.7, 7), new Coordinate2D(3, 9)));
      Polyline polyline9 = PolylineBuilderEx.CreatePolyline(segments, SpatialReferences.WGS84);
      // now do the Related tests
      // Interior/Interior Intersects
      string scl = "T********";
      bool related = GeometryEngine.Instance.Relate(polygon, polyline1, scl);     // related = true
      related = GeometryEngine.Instance.Relate(point0, point1, scl);              // related = false
      related = GeometryEngine.Instance.Relate(point0, multipoint, scl);          // related = true
      related = GeometryEngine.Instance.Relate(multipoint, polygon, scl);         // related = true
      related = GeometryEngine.Instance.Relate(multipoint, polyline1, scl);       // related = false
      related = GeometryEngine.Instance.Relate(polyline2, point2, scl);           // related = false
      related = GeometryEngine.Instance.Relate(point1, polygon, scl);             // related = true
      // Interior/Boundary Intersects
      scl = "*T*******";
      related = GeometryEngine.Instance.Relate(polygon, polyline2, scl);          // related = true
      related = GeometryEngine.Instance.Relate(polygon, polyline3, scl);          // related = false
      related = GeometryEngine.Instance.Relate(point1, polygon, scl);             // related = false
      // Boundary/Boundary Interior intersects
      scl = "***T*****";
      related = GeometryEngine.Instance.Relate(polygon, polyline4, scl);          // related = true
      // Overlaps Dim1
      scl = "1*T***T**";
      related = GeometryEngine.Instance.Relate(polygon, polyline5, scl);          // related = true
      // Crosses Area/Line (LineB crosses PolygonA)
      scl = "1020F1102";
      related = GeometryEngine.Instance.Relate(polygon, polyline6, scl);          // related = false
      related = GeometryEngine.Instance.Relate(polygon, polyline9, scl);          // related = true
      // Boundary/Boundary Touches
      scl = "F***T****";
      related = GeometryEngine.Instance.Relate(polygon, polyline7, scl);          // related = false
      related = GeometryEngine.Instance.Relate(polygon, polyline8, scl);          // related = true
    Requirements
