ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / Rotate Method
The geometry to rotate. If the geometry is an Envelope, then it will be converted to a polygon.
The origin around which the geometry will be rotated.
The rotation angle in radians.
Example
    Rotate Method (IGeometryEngine)
    Rotates the geometry about the specified origin point.
    Syntax
    Parameters
    geometry
    origin
    rotationAngle
    Return Value
    The rotated geometry. If the input geometry is an Envelope, then a polygon is returned. If the input geometry is empty, then an empty geometry is returned.
    Exceptions
    ExceptionDescription
    Either geometry or origin or both are null.
    The method is not implemented for GeometryBag.
    Incompatible spatial references between the input geometries.
    Example
    Rotate a MapPoint
      MapPoint pt = MapPointBuilderEx.CreateMapPoint(1.0, 3.0);
      MapPoint rotatePt = MapPointBuilderEx.CreateMapPoint(3.0, 3.0);
      Geometry result = GeometryEngine.Instance.Rotate(pt, rotatePt, Math.PI / 2);
    // result point is (3, 1)
    Rotate a Polyline
      // rotate a polyline
      MapPoint fixedPt = MapPointBuilderEx.CreateMapPoint(3.0, 3.0);
      List<MapPoint> pts =
        MapPointBuilderEx.CreateMapPoint(1.0, 1.0),
      MapPointBuilderEx.CreateMapPoint(1.0, 5.0),
      MapPointBuilderEx.CreateMapPoint(5, 5),
      MapPointBuilderEx.CreateMapPoint(5.0, 1.0),
      polyline = PolylineBuilderEx.CreatePolyline(pts);
      Polyline rotated = GeometryEngine.Instance.Rotate(polyline, fixedPt, Math.PI / 4) as Polyline;  // rotate 45 deg
    Requirements
