ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / Scale Method / Scale(Geometry,MapPoint,Double,Double) Method
The geometry to scale.
The origin around which the geometry will be scaled.
The scale factor along the X-axis.
The scale factor along the Y-axis.
Example
    Scales the geometry about the specified origin.
    Syntax
    Overloads Function Scale( _
       ByVal geometry As Geometry, _
       ByVal origin As MapPoint, _
       ByVal sx As Double, _
       ByVal sy As Double _
    ) As Geometry
    Parameters
    geometry
    origin
    sx
    sy
    Return Value
    The scaled geometry. If the input geometry is empty, then it is returned unchanged.
    Exceptions
    ExceptionDescription
    Either geometry or origin or both are null.
    The method is not implemented for GeometryBag.
    Incompatible spatial references between the input geometries.
    Remarks
    GeometryEngine Scale
    Example
    Scale a geometry
      List<MapPoint> pts =
        MapPointBuilderEx.CreateMapPoint(1.0, 1.0, 3.0),
      MapPointBuilderEx.CreateMapPoint(1.0, 3.0, 3.0),
      MapPointBuilderEx.CreateMapPoint(3, 3, 3.0),
      MapPointBuilderEx.CreateMapPoint(3.0, 1.0, 3.0),
      MapPoint midPt = MapPointBuilderEx.CreateMapPoint(1.5, 1.5);
      // polyline
      polyline = PolylineBuilderEx.CreatePolyline(pts);
      // polyline.Length = 6
      // polyline.Length3D = 0
      Geometry g = GeometryEngine.Instance.Scale(polyline, midPt, 0.5, 0.5);
      Polyline resultPolyline = g as Polyline;
      // resultPolyline.length  = 3
      // resultPolyline.Points[0] = 1.25, 1.25, 3
      // resultPolyline.Points[1] = 1.25, 2.25, 3
      // resultPolyline.Points[2] = 2.25, 2.25, 3
      // resultPolyline.Points[3] = 2.25, 1.25, 3
      // 3D point - scale in 3d
      MapPoint midPtZ = MapPointBuilderEx.CreateMapPoint(1.5, 1.5, 1);
      g = GeometryEngine.Instance.Scale(polyline, midPtZ, 0.5, 0.5, 0.25);
      // resultPolyline.Points[0] = 1.25, 1.25, 1.5
      // resultPolyline.Points[1] = 1.25, 2.25, 1.5
      // resultPolyline.Points[2] = 2.25, 2.25, 1.5
      // resultPolyline.Points[3] = 2.25, 1.25, 1.5
    Requirements
