ArcGIS.Core.Geometry Namespace / Coordinate3D Structure / CrossProduct Method
The input Coordinate3D to use in the cross product.
Example
    CrossProduct Method
    Constructs the cross product of this Coordinate3D and another Coordinate3D. Vector cross product is used.
    Syntax
    Public Function CrossProduct( _
       ByVal other As Coordinate3D _
    ) As Coordinate3D
    public Coordinate3D CrossProduct(
       Coordinate3D other
    Parameters
    other
    Return Value
    A Coordinate3D representing the cross product of this Coordinate3D and the input Coordinate3D.
    Remarks
    Assume that the magnitude of this Coordinate3D > 0 and the magnitude of the input Coordinate3D > 0. Then the following statements are true:
    If the magnitude of the cross product = 0, then this Coordinate3D and the input Coordinate3D are parallel.
    If the magnitude of the cross product > 0, then the cross product is orthogonal to both this Coordinate3D and the input Coordinate3D.
    Example
    Vector Operations
      // Easy 3D vectors
      Coordinate3D v = new Coordinate3D(0, 1, 0);
      // v.Magnitude = 1
      Coordinate3D other = new Coordinate3D(-1, 0, 0);
      // other.Magnitude = -1
      double dotProduct = v.DotProduct(other);      // dotProduct = 0
      Coordinate3D crossProduct = v.CrossProduct(other);
      // crossProduct.X = 0
      // crossProduct.Y = 0
      // crossProduct.Z = 1
      Coordinate3D addVector = v.AddCoordinate3D(other);
      // addVector.X = -1
      // addVector.Y = 1
      // addVector.Z = 0
      // Rotate around x-axis
      Coordinate3D w = v;
      w.Rotate(Math.PI, other);
      // w.X = 0
      // w.Y = -1
      // w.Z = 0
      w.Scale(0.5);
      // w.X = 0
      // w.Y = -0.5
      // w.Z = 0
      w.Scale(-4);
      // w.X = 0
      // ww.Y = 2
      // w.Z = 0
      // w.Magnitude = 2
      w.Move(3, 2, 0);
      // w.X = 3
      // w.Y = 4
      // w.Z = 0
      // w.Magnitude = 5
      Coordinate3D emptyVector = new Coordinate3D();
      // emptyVector = (0, 0, 0)
      emptyVector.SetEmpty();
      // emptyVector = (Nan, Nan, Nan)
      Coordinate3D c1 = new Coordinate3D(2, 3, 4);
      Coordinate3D c2 = new Coordinate3D(9, -1, 3);
      var result_add = c1 + c2;
      // result_add = (11, 2, 7)
      var result_sub = c1 - c2;
      // result_sub = (-7, 4, 1)
      var b = result_sub != result_add;
      // b = true
      result_add = emptyVector + c1;
      // result_add = (Nan, Nan, Nan)
      b = result_add == emptyVector;
      // b = true
    Requirements
