ArcGIS.Core.Geometry Namespace / Coordinate3D Structure / Move Method
The shift value added to the X-component.
The shift value added to the Y-component.
The shift value added to the Z-component.
Example
    Move Method (Coordinate3D)
    Moves the Coordinate3D by adding a shift value to each component.
    Syntax
    Public Sub Move( _
       ByVal dx As Double, _
       ByVal dy As Double, _
       ByVal dz As Double _
    public void Move(
       double dx,
       double dy,
       double dz
    Parameters
    dx
    dy
    dz
    Example
    Vector Operations
      // Easy 3D vectors
      Coordinate3D v = new Coordinate3D(0, 1, 0);
      // v.Magnitude = 1
      Coordinate3D other = new Coordinate3D(-1, 0, 0);
      // other.Magnitude = -1
      double dotProduct = v.DotProduct(other);      // dotProduct = 0
      Coordinate3D crossProduct = v.CrossProduct(other);
      // crossProduct.X = 0
      // crossProduct.Y = 0
      // crossProduct.Z = 1
      Coordinate3D addVector = v.AddCoordinate3D(other);
      // addVector.X = -1
      // addVector.Y = 1
      // addVector.Z = 0
      // Rotate around x-axis
      Coordinate3D w = v;
      w.Rotate(Math.PI, other);
      // w.X = 0
      // w.Y = -1
      // w.Z = 0
      w.Scale(0.5);
      // w.X = 0
      // w.Y = -0.5
      // w.Z = 0
      w.Scale(-4);
      // w.X = 0
      // ww.Y = 2
      // w.Z = 0
      // w.Magnitude = 2
      w.Move(3, 2, 0);
      // w.X = 3
      // w.Y = 4
      // w.Z = 0
      // w.Magnitude = 5
      Coordinate3D emptyVector = new Coordinate3D();
      // emptyVector = (0, 0, 0)
      emptyVector.SetEmpty();
      // emptyVector = (Nan, Nan, Nan)
      Coordinate3D c1 = new Coordinate3D(2, 3, 4);
      Coordinate3D c2 = new Coordinate3D(9, -1, 3);
      var result_add = c1 + c2;
      // result_add = (11, 2, 7)
      var result_sub = c1 - c2;
      // result_sub = (-7, 4, 1)
      var b = result_sub != result_add;
      // b = true
      result_add = emptyVector + c1;
      // result_add = (Nan, Nan, Nan)
      b = result_add == emptyVector;
      // b = true
    Requirements
