ArcGIS.Core.Geometry Namespace / GeodesicSectorParameter Class / AxisDirection Property
Example
    AxisDirection Property (GeodesicSectorParameter)
    Gets or sets the direction of the major axis of the arc's ellipse as an angle in degrees.
    Syntax
    public double AxisDirection {get; set;}
    Public Property AxisDirection As Double
    Example
    GeodesicSector
      GeodesicSectorParameter param = new()
        ArcVertexCount = 50,
        AxisDirection = Math.PI / 4,
        Center = new Coordinate2D(0, 0),
        LinearUnit = LinearUnit.Meters,
        OutGeometryType = GeometryType.Polygon,
        RadiusVertexCount = 10,
        SectorAngle = 5 * Math.PI / 3,
        SemiAxis1Length = 100000,
        SemiAxis2Length = 20000,
        StartDirection = 11 * Math.PI / 6
      Geometry geometry = GeometryEngine.Instance.GeodesicSector(param, SpatialReferences.WGS84);
      // geometry.IsEmpty = false
      polygon = geometry as Polygon;
      // polygon.PointCount = 68
      // polygon.PartCount = 1
    Requirements
