ArcGIS.Core.Geometry Namespace / Multipart Class / Copy2DCoordinatesToList Method
Example
    Copy2DCoordinatesToList Method (Multipart)
    Gets a copy of all the coordinates in all parts as a read-only list of 2D coordinates.
    Syntax
    Public Function Copy2DCoordinatesToList() As IReadOnlyList(Of Coordinate2D)
    public IReadOnlyList<Coordinate2D> Copy2DCoordinatesToList()
    Return Value
    A readonly list of Coordinate2D.
    Example
    Get the points of a Polyline
      // get the points as a readonly Collection
      //Refer to the initialization region for polyline creation
      ReadOnlyPointCollection pts = polyline.Points;
      int numPts = polyline.PointCount;
      // OR   get an enumeration of the points
      IEnumerator<MapPoint> enumPts = polyline.Points.GetEnumerator();
      // OR   get the point coordinates as a readonly list of Coordinate2D
      IReadOnlyList<Coordinate2D> coordinates = polyline.Copy2DCoordinatesToList();
      // OR   get the point coordinates as a readonly list of Coordinate3D
      IReadOnlyList<Coordinate3D> coordinates3D = polyline.Copy3DCoordinatesToList();
      // OR   get a subset of the collection as Coordinate2D using preallocated memory
      IList<Coordinate2D> coordinate2Ds = new List<Coordinate2D>(10);   // allocate some space
      ICollection<Coordinate2D> subsetCoordinates2D = coordinate2Ds;    // assign
      pts.Copy2DCoordinatesToList(1, 2, ref subsetCoordinates2D);       // copy 2 elements from index 1 into the allocated list
        // coordinate2Ds.Count = 2
        // do something with the coordinate2Ds
      // without allocating more space, obtain a different set of coordinates
      pts.Copy2DCoordinatesToList(5, 9, ref subsetCoordinates2D);       // copy 9 elements from index 5 into the allocated list
        // coordinate2Ds.Count = 9
      // OR   get a subset of the collection as Coordinate3D using preallocated memory
      IList<Coordinate3D> coordinate3Ds = new List<Coordinate3D>(15);   // allocate some space
      ICollection<Coordinate3D> subsetCoordinates3D = coordinate3Ds;    // assign
      pts.Copy3DCoordinatesToList(3, 5, ref subsetCoordinates3D);       // copy 5 elements from index 3 into the allocated list
        // coordinate3Ds.Count = 5
      // OR   get a subset of the collection as MapPoint using preallocated memory
      IList<MapPoint> mapPoints = new List<MapPoint>(7);   // allocate some space
      ICollection<MapPoint> subsetMapPoint = mapPoints;    // assign
      pts.CopyPointsToList(1, 4, ref subsetMapPoint);      // copy 4 elements from index 1 into the allocated list
                                                           // mapPoints.Count = 4
    Get the points of a Polygon
      ReadOnlyPointCollection pts = polygon.Points;
      // get an enumeration of the points
      IEnumerator<MapPoint> enumPts = polygon.Points.GetEnumerator();
      // get the point coordinates as a readonly list of Coordinate2D
      IReadOnlyList<Coordinate2D> coordinates = polygon.Copy2DCoordinatesToList();
      // get the point coordinates as a readonly list of Coordinate3D
      IReadOnlyList<Coordinate3D> coordinates3D = polygon.Copy3DCoordinatesToList();
    Requirements
