ArcGIS.Desktop.Core Namespace / IProjectItem Interface
Members Example
    Provides basic interface for all project items
    Object Model
    IProjectItem InterfaceProjectItemInfo Class
    Syntax
    Public Interface IProjectItem
    public interface IProjectItem
    Remarks
    Any class that is a type of project item must implement IProjectItem. These classes also follow a convention that includes "ProjectItem" as part of their name
    Example
    //create a new FolderConnectionProjectItem
    var folderLocationItem = ItemFactory.Instance.Create(@"C:\temp\mydata");
    await QueuedTask.Run(() => Project.Current.AddItem(folderLocationItem as IProjectItem);
    Create an IProjectItem from a layout template pagx file and add it to the project
      var templateFileName = "Layout.pagx";
      // Get layout Template Path from the project's home folder and combine it with a file name
      var projectPath = CoreModule.CurrentProject.HomeFolderPath;
      var layoutTemplateFilePath = System.IO.Path.Combine(projectPath, templateFileName);
      // Create a new layout project item with the layout file path
      // Create an IProjectItem using a layout template pagx file
      IProjectItem pagx = ItemFactory.Instance.Create(layoutTemplateFilePath) as IProjectItem;
      // Add the IProjectItem to the current project
      //Note: Needs QueuedTask to run
      Project.Current.AddItem(pagx);
    Import a pagx into a project
      //Create a layout project item from importing a pagx file
                                @"C:\Temp\Layout.pagx") as IProjectItem;
    Import a report file
      var reportFilePath = @"c:\temp\Report.rptx";
      //Note: Call within QueuedTask.Run()
      Item reportToImport = ItemFactory.Instance.Create(reportFilePath);
      Project.Current.AddItem(reportToImport as IProjectItem);
    Requirements
