ArcGIS.Core.Arcade Namespace / ArcadeEvaluationResult Class / GetResult Method
Example
    GetResult Method
    Gets the result of the expression. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetResult() As Object
    public object GetResult()
    Return Value
    The value of the arcade expression evaluation.
    Exceptions
    ExceptionDescription
    Example
    Basic Query
      //Consult https://github.com/Esri/arcade-expressions/ and
      //https://developers.arcgis.com/arcade/ for more examples
      //and arcade reference
      // Note: the following should be embedded in a QueuedTask.Run() statement
        //construct an expression
        var query = @"Count($layer)";//count of features in "layer"
        //construct a CIMExpressionInfo
        var arcade_expr = new CIMExpressionInfo()
          Expression = query.ToString(),
          //Return type can be string, numeric, or default
          //When set to default, add-in is responsible for determining
          //the return type
          ReturnType = ExpressionReturnType.Default
        //Construct an evaluator
        //select the relevant profile - it must support Pro and it must
        //contain any profile variables you are using in your expression.
        //Consult: https://developers.arcgis.com/arcade/profiles/
        using var arcade = ArcadeScriptEngine.Instance.CreateEvaluator(
                                arcade_expr, ArcadeProfile.Popups);
        //Provision  values for any profile variables referenced...
        //in our case '$layer'
        var variables = new List<KeyValuePair<string, object>>() {
            new("$layer", featureLayer)
        //evaluate the expression
        try
          var result = arcade.Evaluate(variables).GetResult();
          System.Diagnostics.Debug.WriteLine($"Result: {result}");
        //handle any exceptions
        catch (InvalidProfileVariableException)
          //something wrong with the profile variable specified
          //TODO...
        catch (EvaluationException)
          //something wrong with the query evaluation
          //TODO...
    Basic Query using Features
        var query = @"$feature.AreaInAcres * 43560.0";//convert acres to ft 2
          //the return type
        //we are evaluating the expression against all features
        using var rc = featureLayer.Search();
        while (rc.MoveNext())
          //in our case '$feature'
              new("$feature", rc.Current)
          //evaluate the expression (per feature in this case)
          try
            var val = ((double)result).ToString("0.0#");
              $"{rc.Current.GetObjectID()} area: {val} ft2");
            //TODO...
            //TODO...
    Retrieve features using FeatureSetByName
        //construct a query
        var query = new StringBuilder();
        var layer_name = "USA Current Wildfires - Current Incidents";
        //https://developers.arcgis.com/arcade/function-reference/featureset_functions/
        query.AppendLine(
          $"var features = FeatureSetByName($map,'{layer_name}', ['*'], false);");
        query.AppendLine("return Count(features);");
          //the return type
        //in our case '$map'
            new("$map", map)
        try
          //TODO...
          //TODO...
    Retrieve features using Filter
        //construct a query
        query.AppendLine(
          "var features = Filter($layer, 'DailyAcres is not NULL');");
          //the return type
        try
          //TODO...
          //TODO...
    Calculate basic statistics with Math functions
        //construct a query
        //https://developers.arcgis.com/arcade/function-reference/math_functions
        query.AppendLine("var features = Filter($layer, 'DailyAcres is not NULL');");
        query.AppendLine("var count_feat = Count(features);");
        query.AppendLine("var sum_feat = Sum(features, 'DailyAcres');");
        query.AppendLine("var max_feat = Max(features, 'DailyAcres');");
        query.AppendLine("var min_feat = Min(features, 'DailyAcres');");
        query.AppendLine("var avg_feat = Average(features, 'DailyAcres');");
        query.AppendLine("var answer = [count_feat, sum_feat, max_feat, min_feat, avg_feat]");
        query.AppendLine("return Concatenate(answer,'|');");
          //the return type
        try
          //TODO...
          //TODO...
    Using FeatureSet functions Filter and Intersects
        //construct a query
        //Assume we have two layers - a polygon and a points layer.
        //Select all points within the relevant polygon boundaries and sum the count
        query.AppendLine("var results = [];");
        query.AppendLine("var polygons = FeatureSetByName($map, 'PolygonLayerName', ['*'], true);");
        query.AppendLine("var sel_polygons = Filter(polygons, 'IDField IN (2, 15, 16)');");
        query.AppendLine("for(var polygon in sel_polygons) {");
        query.AppendLine("   var name = polygon.Name;");
        query.AppendLine("   var PointsInPolygon = Count(Intersects($layer, Geometry(polygon)));");
        query.AppendLine("   Insert(results, 0, pointsInPolygon);");
        query.AppendLine("   Insert(results, 0, name);");
        query.AppendLine("}");
        query.AppendLine("return Concatenate(results,'|');");
          //the return type
        //in our case '$layer' and '$map'
        List<KeyValuePair<string, object>> variables = [
            new("$layer", pointsLayer),
            new("$map", map)
        try
          var results = result.ToString().Split('|', StringSplitOptions.None);
          var entries = results.Length / 2;
          int i = 0;
          for (var e = 0; e < entries; e++)
            var name = results[i++];
            var count = results[i++];
            System.Diagnostics.Debug.WriteLine($"'{name}' points count: {count}");
          //TODO...
          //TODO...
    Evaluating an Arcade Labeling Expression
      string ArcadeLabelingExpressionName = "My Arcade Label Expression";
        //Given a layer that has an arcade labeling
        //expression and we evaluate it interactively...
        var def = featureLayer.GetDefinition() as CIMFeatureLayer;
        //Get the label class
        var label_class = def.LabelClasses
                           .FirstOrDefault(lc =>
                             return lc.Name == ArcadeLabelingExpressionName &&
                                    lc.ExpressionEngine == LabelExpressionEngine.Arcade;
        if (label_class == null)
          return;
        //evaluate the label expression against the features
        var expr_info = new CIMExpressionInfo()
          Expression = label_class.Expression,
          ReturnType = ExpressionReturnType.String
        //https://developers.arcgis.com/arcade/profiles/labeling/
                                                  expr_info, ArcadeProfile.Labeling);
        //loop through the features
          //output
             $"[{rc.Current.GetObjectID()}]: {result}");
    Evaluating Arcade Visual Variable Expressions on a Renderer
        //Assume we have a layer that is using Visual Variable
        //expressions that we want to evaluate interactively...
        //Most all feature renderers have a VisualVariable collection
        var renderer = def.Renderer as CIMUniqueValueRenderer;
        List<CIMVisualVariable> vis_variables = renderer.VisualVariables?.ToList() ??
        if (vis_variables.Count == 0)
          return;//there are none
        var vis_var_with_expr = new Dictionary<string, string>();
        //see if any are using expressions
        foreach (var vv in vis_variables)
          if (vv is CIMColorVisualVariable cvv)
            if (!string.IsNullOrEmpty(cvv.ValueExpressionInfo?.Expression))
              vis_var_with_expr.Add("Color", cvv.ValueExpressionInfo?.Expression);
          else if (vv is CIMTransparencyVisualVariable tvv)
            if (!string.IsNullOrEmpty(tvv.ValueExpressionInfo?.Expression))
              vis_var_with_expr.Add("Transparency", tvv.ValueExpressionInfo?.Expression);
          else if (vv is CIMSizeVisualVariable svv)
            if (!string.IsNullOrEmpty(svv.ValueExpressionInfo?.Expression))
              vis_var_with_expr.Add("Outline", svv.ValueExpressionInfo?.Expression);
        if (vis_var_with_expr.Count == 0)
          return;//there aren't any with expressions
        //loop through the features (outer)
        //per feature evaluate each visual variable.... (inner)
        //the converse is to loop through the expressions (outer)
        //then per feature evaluate the expression (inner)
        using RowCursor rc = featureLayer.Search();
          foreach (var kvp in vis_var_with_expr)
              Expression = kvp.Value,
            //per feature eval each expression...
            using ArcadeEvaluator arcade = ArcadeScriptEngine.Instance.CreateEvaluator(
                                        expr_info, ArcadeProfile.Visualization);
            //note 2D maps can also have view scale...
            //...if necessary...
            if (mv.ViewingMode == MapViewingMode.Map)
              variables.Add(new("$view.scale", mv.Camera.Scale));
            var result = arcade.Evaluate(variables).GetResult().ToString();
            //output
               $"[{rc.Current.GetObjectID()}] '{kvp.Key}': {result}");
    Requirements
    ArcGIS Pro version: 3.2 or higher.
