ArcGIS.Core.Arcade Namespace / ArcadeScriptEngine Class / CreateEvaluator Method
Example
    CreateEvaluator Method (ArcadeScriptEngine)
    Creates an instance of an Arcade script evaluator. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    expressionInfo
    profile
    Return Value
    Exceptions
    ExceptionDescription
    Exception thrown when there has been a parsing error
    Example
    var expressionInfo = new CIMExpressionInfo()
      Expression = "$feature.objectid",
      ExpressionReturnType = CIMExpressionReturnType.String
    try
      using (var arcade = ArcadeScriptEngine.Instance.CreateEvaluator(expressionInfo, ArcadeProfile.Visualization))
    catch (ParsingException ex)
      System.Diagnostics.Trace.WriteLine(ex);
    Basic Query
      //Consult https://github.com/Esri/arcade-expressions/ and
      //https://developers.arcgis.com/arcade/ for more examples
      //and arcade reference
      // Note: the following should be embedded in a QueuedTask.Run() statement
        //construct an expression
        var query = @"Count($layer)";//count of features in "layer"
        //construct a CIMExpressionInfo
        var arcade_expr = new CIMExpressionInfo()
          Expression = query.ToString(),
          //Return type can be string, numeric, or default
          //When set to default, add-in is responsible for determining
          //the return type
          ReturnType = ExpressionReturnType.Default
        //Construct an evaluator
        //select the relevant profile - it must support Pro and it must
        //contain any profile variables you are using in your expression.
        //Consult: https://developers.arcgis.com/arcade/profiles/
        using var arcade = ArcadeScriptEngine.Instance.CreateEvaluator(
                                arcade_expr, ArcadeProfile.Popups);
        //Provision  values for any profile variables referenced...
        //in our case '$layer'
        var variables = new List<KeyValuePair<string, object>>() {
            new("$layer", featureLayer)
        //evaluate the expression
        try
          var result = arcade.Evaluate(variables).GetResult();
          System.Diagnostics.Debug.WriteLine($"Result: {result}");
        //handle any exceptions
        catch (InvalidProfileVariableException)
          //something wrong with the profile variable specified
          //TODO...
        catch (EvaluationException)
          //something wrong with the query evaluation
          //TODO...
    Basic Query using Features
        var query = @"$feature.AreaInAcres * 43560.0";//convert acres to ft 2
          //the return type
        //we are evaluating the expression against all features
        using var rc = featureLayer.Search();
        while (rc.MoveNext())
          //in our case '$feature'
              new("$feature", rc.Current)
          //evaluate the expression (per feature in this case)
          try
            var val = ((double)result).ToString("0.0#");
              $"{rc.Current.GetObjectID()} area: {val} ft2");
            //TODO...
            //TODO...
    Requirements
    ArcGIS Pro version: 3.2 or higher.
