ArcGIS.Core.Arcade Namespace / IArcadeScriptEngine Interface
    IArcadeScriptEngine Interface Methods
    For a list of all members of this type, see IArcadeScriptEngine members.
    Public Methods
     NameDescription
     Method Creates an instance of an Arcade script evaluator. This method must be called on the MCT. Use QueuedTask.Run.
     Method Gets the minimum required version of Arcade needed for the given expression. This method must be called on the MCT. Use QueuedTask.Run.
     Method Gets the current version of Arcade in use by this engine. This method must be called on the MCT. Use QueuedTask.Run.
    Top
