ArcGIS.Desktop.Framework.Controls Namespace / EmbeddableControl Class / Create Method / Create(String,String,XElement,Boolean) Method
The DAML ID of the component declaring the EmbeddedControl.
The DAML category containing the EmbeddableControl
The XML configuration data.
True if the options can be edited. Default is false
Example
    Creates an instance of an EmbeddableControl and its View in a ViewModel-View fashion.
    Syntax
    Public Overloads Shared Function Create( _
       ByVal damlID As String, _
       ByVal category As String, _
       ByVal options As XElement, _
       Optional ByVal canChangeOptions As Boolean _
    ) As Tuple(Of EmbeddableControl,UserControl)
    Parameters
    damlID
    category
    options
    canChangeOptions
    Return Value
    The ViewModel-View pair.
    Remarks
    This function assumes the EmbeddableControl is registered in the DAML category passed in as a parameter. The DAML definition must additionally contain the View associated with the EmbeddableControl.
    Example
    <categories>
      <updateCategory refID="esri_embeddableControls">
        <insertComponent id="EmbeddedDockPane_control" className="SampleEmbeddableControlViewModel">
          <content className="SampleEmbeddableControlView" relatedCommand="EmbeddedDockPane_SampleDockPane_ShowButton" />
        </insertComponent>
      </updateCategory>
    </categories>
    Requirements
