ArcGIS.Desktop.Layouts Namespace / Element Class / GetDefinition Method
Example
    GetDefinition Method (Element)
    Returns the element's CIM definition. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overridable Function GetDefinition() As CIMElement
    public virtual CIMElement GetDefinition()
    Return Value
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    Example
    Set halo property of north arrow
      //Set the CIM halo properties of a north arrow.
      //Reference the first selected north arrow element
      var northArrow = LayoutView.Active.GetSelectedElements().OfType<NorthArrow>().First();
      //Note: Must be on QueuedTask.Run
      //Get definition of north arrow...
      var cim = northArrow.GetDefinition() as CIMMarkerNorthArrow;
      //this halo symbol is 50% transparent, no outline (i.e. 0 width)
      //First construct a polygon symbol to use in the Halo
      //Polygon symbol will need a fill and a stroke
      var polyFill = SymbolFactory.Instance.ConstructSolidFill(ColorFactory.Instance.CreateRGBColor(0, 0, 0, 50));
      var polyStroke = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.BlackRGB, 0);
      var haloPoly = SymbolFactory.Instance.ConstructPolygonSymbol(polyFill, polyStroke);
      //Set the north arrow definition of HaloSymbol and HaloSize
      ((CIMPointSymbol)cim.PointSymbol.Symbol).HaloSymbol = haloPoly;
      ((CIMPointSymbol)cim.PointSymbol.Symbol).HaloSize = 3;//size of the halo
      //Apply the CIM changes back to the element
      northArrow.SetDefinition(cim);
    Lock an element
      // The Locked property is displayed in the TOC as a lock symbol next
      // to each element.  If locked the element can't be selected in the layout
      // using the graphic selection tools.
      //Reference an element
      if (element != null)
        // Modify the Locked property via the CIM
        CIMElement CIMElement = element.GetDefinition() as CIMElement;
        CIMElement.Locked = true;
        element.SetDefinition(CIMElement);
    Apply a Background Color to a MapFrame
      //Apply a background color to the map frame element using the CIM.
      //Get the map frame's definition in order to modify the background.
      var mapFrameDefn = mapFrame.GetDefinition() as CIMMapFrame;
      //Construct the polygon symbol to use to create a background
      var polySymbol = SymbolFactory.Instance.ConstructPolygonSymbol(
                      ColorFactory.Instance.BlueRGB, SimpleFillStyle.Solid);
      //Set the background
      mapFrameDefn.GraphicFrame.BackgroundSymbol =
                                        polySymbol.MakeSymbolReference();
      //Set the map frame definition
      mapFrame.SetDefinition(mapFrameDefn);
    Requirements
