Parameters
- height
- Double
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method must be called within the lambda passed to QueuedTask.Run. |
| System.InvalidOperationException | This element requires its mapview to be active |
//Note: Must be on QueuedTask.Run
//Build geometry
Coordinate2D center = new Coordinate2D(7, 5.5);
//Reference a North Arrow in a style
StyleProjectItem stylePrjItm = Project.Current.GetItems<StyleProjectItem>()
.FirstOrDefault(item => item.Name == "ArcGIS 2D");
NorthArrowStyleItem naStyleItm = stylePrjItm.SearchNorthArrows(
"ArcGIS North 10")[0];
//Reference MF, create north arrow and add to layout
var mf = layout.FindElement("Map Frame") as MapFrame;
var narrow_info = new NorthArrowInfo()
MapFrameName = mf.Name,
NorthArrowStyleItem = naStyleItm
var arrowElm = (NorthArrow)ElementFactory.Instance.CreateMapSurroundElement(
layout, center.ToMapPoint(), narrow_info) as NorthArrow;
arrowElm.SetName("New North Arrow");
arrowElm.SetHeight(1.75);
arrowElm.SetX(7);
arrowElm.SetY(6);
