ArcGIS.Desktop.Layouts Namespace / Element Class / SetLockedAspectRatio Method
Double
    SetLockedAspectRatio Method (Element)
    Sets the locked aspect ratio value of the element. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetLockedAspectRatio(
       bool lockedAspectRatio
    Public Sub SetLockedAspectRatio( _
       ByVal lockedAspectRatio As Boolean _
    Parameters
    lockedAspectRatio
    Double
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    This element requires its mapview to be active
    Remarks
    When set to true, this means if element width is set, then the element height will be automatically adjusted appropriately. The same is true if height were modified, then width would automatically be adjusted.
    Placement for an element contained in graphics layer requires the mapview be active.
    Requirements
