ArcGIS.Desktop.Layouts Namespace / Element Class / SetRotation Method
Double
    SetRotation Method (Element)
    Sets the rotation value for the element. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetRotation( _
       ByVal rotation As Double _
    public void SetRotation(
       double rotation
    Parameters
    rotation
    Double
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    This element requires its mapview to be active
    Remarks
    Positive values rotate the element counter-clockwise, negative values rotate the element clockwise.
    Placement for an element contained in graphics layer requires the mapview be active.
    Requirements
