ArcGIS.Desktop.Mapping Namespace / IStandaloneTableFactory Interface / CreateStandaloneTable Method
    CreateStandaloneTable Method (IStandaloneTableFactory)
    Overload List
    OverloadDescription
    Creates a new StandaloneTable instance with the specified path to a dataset and adds it to a container such as a map. Optionally you can provide a name to override the default display name. This method must be called on the MCT. Use QueuedTask.Run.
    Creates a new StandaloneTable instance using the specified StandaloneTableCreationParams and adds it to a container such as a map. This method must be called on the MCT. Use QueuedTask.Run.
    Requirements
