ArcGIS.Desktop.Mapping Namespace / ISymbolFactory Interface / ConstructMarkerFromFile Method
The full path to file on disk.
Example
    ConstructMarkerFromFile Method (ISymbolFactory)
    Constructs a marker from file. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    CIMMarker ConstructMarkerFromFile(
       string file
    Function ConstructMarkerFromFile( _
       ByVal file As String _
    ) As CIMMarker
    Parameters
    file
    Return Value
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run
    Remarks
    Marker can be created from the following file formats: JPG, BMP, PNG, GIF, EMF, 3DS, FLT, DAE, OBJ, SVG, GLTF, GLB, FBX, DWG, IFC, USDC, USDZ, GML
    Example
    How to construct a point symbol from a file on disk
      //The following file formats can be used to create the marker: DAE, 3DS, FLT, EMF, JPG, PNG, BMP, GIF
      await QueuedTask.Run(() =>
        CIMMarker markerFromFile = SymbolFactory.Instance.ConstructMarkerFromFile(@"C:\Temp\fileName.dae");
        CIMPointSymbol pointSymbolFromFile = SymbolFactory.Instance.ConstructPointSymbol(markerFromFile);
    Requirements
