ArcGIS.Desktop.Mapping Namespace / ISymbolFactory Interface / ConstructMarkerFromStream Method
The stream representing the image.
Example
    ConstructMarkerFromStream Method (ISymbolFactory)
    Constructs a marker from a stream.
    Syntax
    CIMMarker ConstructMarkerFromStream(
       Stream stream
    Function ConstructMarkerFromStream( _
       ByVal stream As Stream _
    ) As CIMMarker
    Parameters
    stream
    Return Value
    Remarks
    Marker can be created from the following stream data type: JPG, BMP, PNG, GIF
    Example
    How to construct a point symbol from a in memory graphic
      //Create a stream for the image
      //At 3.0 you need https://www.nuget.org/packages/Microsoft.Windows.Compatibility
      //System.Drawing
      System.Drawing.Image newImage = System.Drawing.Image.FromFile(@"C:\PathToImage\Image.png");
      var stream = new System.IO.MemoryStream();
      newImage.Save(stream, System.Drawing.Imaging.ImageFormat.Png);
      stream.Position = 0;
      //Create marker using the stream
      CIMMarker markerFromStream = SymbolFactory.Instance.ConstructMarkerFromStream(stream);
      //Create the point symbol from the marker
      CIMPointSymbol pointSymbolFromStream = SymbolFactory.Instance.ConstructPointSymbol(markerFromStream);
    Requirements
