ArcGIS.Desktop.Mapping Namespace / ISymbolFactory Interface / ConstructPolygonSymbol Method / ConstructPolygonSymbol(CIMColor) Method
ArcGIS.Core.CIM.CIMColor
Example
    Constructs a polygon symbol of specific color.
    Syntax
    CIMPolygonSymbol ConstructPolygonSymbol(
       CIMColor color
    Overloads Function ConstructPolygonSymbol( _
       ByVal color As CIMColor _
    ) As CIMPolygonSymbol
    Parameters
    color
    Return Value
    Example
    How to get symbol reference from a symbol
      CIMPolygonSymbol polySymbol = SymbolFactory.Instance.ConstructPolygonSymbol(ColorFactory.Instance.RedRGB);
      //Get symbol reference from the symbol
      CIMSymbolReference symbolReference = polySymbol.MakeSymbolReference();
    Get the map clipping geometry
      var mapWithClip = MapView.Active.Map;
      await QueuedTask.Run(() =>
        //If clipping is set to ArcGIS.Core.CIM.ClippingMode.None or ArcGIS.Core.CIM.ClippingMode.MapSeries null is returned
        //If clipping is set to ArcGIS.Core.CIM.ClippingMode.MapExtent the ArcGIS.Core.CIM.CIMMap.CustomFullExtent is returned.
        //Otherwise, if clipping is set to ArcGIS.Core.CIM.ClippingMode.CustomShape the custom clip polygon is returned.
        var poly = mapWithClip.GetClipGeometry();
        //You can use the polygon returned
        //For example: We make a polygon graphic element and add it to a Graphics Layer.
        var gl = mapWithClip.GetLayersAsFlattenedList().OfType<GraphicsLayer>().FirstOrDefault();
        if (gl == null)
          return;
        var polygonSymbol = SymbolFactory.Instance.ConstructPolygonSymbol(CIMColor.CreateRGBColor(255, 255, 0));
        var cimGraphicElement = new CIMPolygonGraphic
          Polygon = poly,
          Symbol = polygonSymbol.MakeSymbolReference()
        gl.AddElement(cimGraphicElement);
    Polygon Graphic Element using CIMGraphic
        //Place a polygon symbol using the mapview extent geometry
        var extent = mapView.Extent;
        //Contract the extent
        var polygonEnv = extent.Expand(-100000, -90000, false);
        //create a polygon using the envelope
        var polygon = PolygonBuilderEx.CreatePolygon(polygonEnv);
        //specify a symbol
        var poly_symbol = SymbolFactory.Instance.ConstructPolygonSymbol(
                              ColorFactory.Instance.GreenRGB);
        //create a CIMGraphic
        var graphic = new CIMPolygonGraphic()
          Symbol = poly_symbol.MakeSymbolReference(),
          Polygon = polygon,
        graphicsLayer.AddElement(graphic);
    Class Breaks renderer with Manual Intervals
    /// <summary>
    /// Renders a feature layer using graduated colors and manual intervals to draw quantities.
    /// ![cb-colors-manual-breaks.png](https://ArcGIS.github.io/arcgis-pro-sdk/images/Renderers/cb-colors-manual-breaks.png)
    /// </summary>
      //Check feature layer name
      //Code works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data
      var featureLayer = activeMap.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault(f => f.Name == "USDemographics");
      if (featureLayer == null)
        MessageBox.Show("This renderer works with the USDemographics feature layer available with the ArcGIS Pro SDK Sample data", "Data missing");
      //Change these class breaks to be appropriate for your data. These class breaks defined below apply to the US States feature class
      List<CIMClassBreak> listClassBreaks = new List<CIMClassBreak>
              new CIMClassBreak
                  Symbol = SymbolFactory.Instance.ConstructPolygonSymbol(ColorFactory.Instance.RedRGB).MakeSymbolReference(),
                  UpperBound = 24228
              new CIMClassBreak
                  Symbol = SymbolFactory.Instance.ConstructPolygonSymbol(ColorFactory.Instance.GreenRGB).MakeSymbolReference(),
                  UpperBound = 67290
              new CIMClassBreak
                  Symbol = SymbolFactory.Instance.ConstructPolygonSymbol(ColorFactory.Instance.BlueRGB).MakeSymbolReference(),
                  UpperBound = 121757
               new CIMClassBreak
                  Symbol = SymbolFactory.Instance.ConstructPolygonSymbol(ColorFactory.Instance.GreyRGB).MakeSymbolReference(),
                  UpperBound = 264435
                new CIMClassBreak
                  Symbol = SymbolFactory.Instance.ConstructPolygonSymbol(ColorFactory.Instance.WhiteRGB).MakeSymbolReference(),
                  UpperBound = 576594
      CIMClassBreaksRenderer cimClassBreakRenderer = new CIMClassBreaksRenderer
        ClassBreakType = ClassBreakType.GraduatedColor,
        ClassificationMethod = ClassificationMethod.Manual,
        Field = "NumericFieldInLayer",
        //Important to add the Minimum break for your data to be classified correctly.
        //This is vital especially if you have data with negative values.
        //MinimumBreak =
        Breaks = listClassBreaks.ToArray()
      await QueuedTask.Run(() => featureLayer?.SetRenderer(cimClassBreakRenderer));
    Procedural Symbol
    /// <summary>
    /// Create a procedural symbol that can be applied to a polygon building footprint layer
    /// ![ProceduralSymbol](https://ArcGIS.github.io/arcgis-pro-sdk/images/Symbology/polygon-procedural.png)
    /// Note: The rule package used in this method can be obtained from the Sample Data included in the arcgis-pro-sdk-community-samples repository.
    /// </summary>
      //Note: Run withing QueuedTask
      string _rulePkgPath = @"C:\Data\RulePackages\Venice_2014.rpk";
      //Polygon symbol to hold the procedural layer
      var proceduralSymbol = SymbolFactory.Instance.ConstructPolygonSymbol();
      //Array of layers to hold a procedural symbol layer
      CIMSymbolLayer[] proceduralSymbolLyr =
                new CIMProceduralSymbolLayer()
                    PrimitiveName = "Venice Rule package 2014",
                    RulePackage = _rulePkgPath,
                    RulePackageName = "Venice_2014",
      proceduralSymbol.SymbolLayers = proceduralSymbolLyr;
      //To apply the symbol to a polygon feature layer
      //var renderer = theLayer.GetRenderer() as CIMSimpleRenderer;
      //renderer.Symbol = proceduralSymbol.MakeSymbolReference();
      //theLayer.SetRenderer(renderer);
    Requirements
