ArcGIS.Desktop.Mapping Namespace / ISymbolFactory Interface / ConstructProceduralSymbol Method
full path to a rule package
FeatureLayer
ArcGIS.Core.CIM.CIMPrimitiveOverride
    ConstructProceduralSymbol Method (ISymbolFactory)
    Create a symbol reference with a procedural symbol layer for a rule package. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    rulePackagePath
    featureLayer
    FeatureLayer
    overrides
    Return Value
    Exceptions
    ExceptionDescription
    {rulePackagePath} not found or is inaccessible
    Invalid layer geometry type
    Rule package geometry type not compatible with FeatureClass geometry type.
    Procedural symbol cannot be applied to rasterized feature layers. Feature layers that are in the 2D Layers group in the Contents pane are rasterized
    Call to retrieve rule package attributes failed.
    Cannot use rule packages that create leaf shapes with procedural symbols.
    Remarks
    Pass in null (default) for the overrides parameter to have default field mappings applied in the renderer
    Requirements
