ArcGIS.Desktop.Mapping Namespace / ISymbolFactory Interface / LayerIsCompatibleWithRulePackage Method
The full path to the rule package
The layer to check the compatibility of the rule package against
    LayerIsCompatibleWithRulePackage Method (ISymbolFactory)
    Checks the compatibility of the rule package geometry with the feature layer shape type for use as a renderer. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    bool LayerIsCompatibleWithRulePackage(
       string rulePackagePath,
       FeatureLayer featureLayer
    Function LayerIsCompatibleWithRulePackage( _
       ByVal rulePackagePath As String, _
       ByVal featureLayer As FeatureLayer _
    ) As Boolean
    Parameters
    rulePackagePath
    featureLayer
    Return Value
    True if the geometry type of the rule package matches the geometry type of the layer
    Exceptions
    ExceptionDescription
    {rulePackagePath} not found or is inaccessible
    Cannot use rule packages that create leaf shapes with procedural symbols.
    Invalid layer geometry type.
    Procedural symbol cannot be applied to rasterized feature layers. Feature layers that are in the 2D Layers group in the Contents pane are rasterized
    Remarks
    Checks:
    • The rule package is supported (geometry output type must be combined shape)
    • The output geometry of the features (in the feature layer) is one of "Point | Polygon | Multi-path"
    • The feature layer is not flattened (i.e. Procedural symbols cannot be applied to feature layers that are in the 2D Layers group. They will be rasterized. Procedural symbols can only be applied to layers in the 3D Layers group
    • The input geometry type of the rule package matches the geometry type of the layer
    Requirements
