ArcGIS.Desktop.Mapping Namespace / ISymbolFactory Interface / ShapeTypeSupportedWithRulePackage Method
The layer to check the shapetype of
    ShapeTypeSupportedWithRulePackage Method (ISymbolFactory)
    Checks if the underlying shape type of the layer features is supported for use with rule package renderers. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    bool ShapeTypeSupportedWithRulePackage(
       FeatureLayer featureLayer
    Function ShapeTypeSupportedWithRulePackage( _
       ByVal featureLayer As FeatureLayer _
    ) As Boolean
    Parameters
    featureLayer
    Return Value
    bool
    Exceptions
    ExceptionDescription
    Remarks
    Point, Polygon, and Multipatch shape types are supported.
    Requirements
