Parameters
- file
- The full path to file on disk.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method must be called within the lambda passed to QueuedTask.Run |
//The following file formats can be used to create the marker: DAE, 3DS, FLT, EMF, JPG, PNG, BMP, GIF
//Note: Run within QueuedTask.Run
CIMMarker markerFromFile = SymbolFactory.Instance.ConstructMarkerFromFile(@"C:\Temp\fileName.dae");
CIMPointSymbol pointSymbolFromFile = SymbolFactory.Instance.ConstructPointSymbol(markerFromFile);
