ArcGIS.Desktop.Mapping Namespace / SymbolFactory Class / GetRulePackageDescription Method
the path to the rule package
    GetRulePackageDescription Method (SymbolFactory)
    Populate the associated rule package description. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetRulePackageDescription( _
       ByVal rulePackagePath As String _
    ) As RulePackageDescription
    public RulePackageDescription GetRulePackageDescription(
       string rulePackagePath
    Parameters
    rulePackagePath
    Return Value
    A populated rule package description.
    Exceptions
    ExceptionDescription
    {rulePackagePath} not found or is inaccessible
    Cannot use rule packages that create leaf shapes with procedural symbols.
    Call to retrieve rule package attributes failed.
    Remarks
    Package description includes the geometry type and all (non-hidden) rule package attributes.
    Requirements
