ArcGIS.Core.Data Namespace / VersionManager Class / GetVersion Method
The name of the Version to return.
Example
    GetVersion Method (VersionManager)
    Gets a Version object with the specified name. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public Version GetVersion(
       string name
    Public Function GetVersion( _
       ByVal name As String _
    ) As Version
    Parameters
    name
    Return Value
    The Version that corresponds to name.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    Connecting to a Version
      Task<Geodatabase> ConnectToVersionAsync(Geodatabase geodatabase, string versionName) => QueuedTask.Run(() =>
        Geodatabase connectedVersion = null;
        if (geodatabase.IsVersioningSupported())
          using (VersionManager versionManager = geodatabase.GetVersionManager())
          using (Version version = versionManager.GetVersion(versionName))
            connectedVersion = version.Connect();
        return connectedVersion;
    Working with Versions
      await QueuedTask.Run(() =>
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file"))))
          IReadOnlyList<string> versionNames = versionManager.GetVersionNames();
          Version defaultVersion = versionManager.GetDefaultVersion();
          string testVersionName = versionNames.First(v => v.Contains("Test"));
          Version testVersion = versionManager.GetVersion(testVersionName);
          Version qaVersion = defaultVersion.GetChildren().First(version => version.GetName().Contains("QA"));
          Geodatabase qaVersionGeodatabase = qaVersion.Connect();
          FeatureClass currentFeatureClass = geodatabase.OpenDataset<FeatureClass>("featureClassName");
          FeatureClass qaFeatureClass = qaVersionGeodatabase.OpenDataset<FeatureClass>("featureClassName");
    Switching between versions
      Task ChangeVersionsAsync(Geodatabase geodatabase, string toVersionName)
        var map = MapView.Active?.Map;
        if (map == null)
          return Task.CompletedTask;
        return QueuedTask.Run(() =>
            VersionBaseType versionBaseType = versionManager.GetCurrentVersionBaseType();
            if (versionBaseType == VersionBaseType.Version)
              Version fromVersion = versionManager.GetCurrentVersion();
              Version toVersion = versionManager.GetVersion(toVersionName);
              // Switch between versions
              map.ChangeVersion(fromVersion, toVersion);
            if (versionBaseType == VersionBaseType.HistoricalVersion)
              HistoricalVersion fromHistoricalVersion = versionManager.GetCurrentHistoricalVersion();
              HistoricalVersion toHistoricalVersion = versionManager.GetHistoricalVersion(toVersionName);
              // Switch between historical versions
              map.ChangeVersion(fromHistoricalVersion, toHistoricalVersion);
            // Switch from HistoricalVersion to Version and vice-versa
            // map.ChangeVersion(fromHistoricalVersion, toVersion);
            // map.ChangeVersion(fromVersion, toHistoricalVersion);
    Requirements
