ArcGIS.Desktop.Core Namespace / IMetadata Interface / GetXml Method
Example
    GetXml Method (IMetadata)
    Gets the item’s metadata XML document as a string.
    Syntax
    string GetXml()
    Function GetXml() As String
    Return Value
    Metadata xml string
    Remarks
    Not all items support metadata. Be sure to check for empty string or null as the return value from GetXml.
    Example
    Item: Get an item's metadata: GetXML
      string gdbXMLMetadataXmlAsString = string.Empty;
      gdbXMLMetadataXmlAsString = await QueuedTask.Run(() => gdbMetadataItem.GetXml());
      //check metadata was returned
      if (!string.IsNullOrEmpty(gdbXMLMetadataXmlAsString))
        //use the metadata
    Requirements
