Return Value
true if the metadata can be edited
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
// Note: Needs QueuedTask to run
var xmlMetadata = File.ReadAllText(@"E:\Data\Metadata\MetadataForFeatClass.xml");
//Will throw InvalidOperationException if the metadata cannot be changed
//so check "CanEdit" first
if (featureClassMetadataItem.CanEdit())
featureClassMetadataItem.SetXml(xmlMetadata);
bool canEdit;
//Call CanEdit before calling SetXml
canEdit = metadataItemToCheck.CanEdit();
