ArcGIS.Desktop.Mapping Namespace / IMapViewOverlayControl Interface
    IMapViewOverlayControl Interface Properties
    For a list of all members of this type, see IMapViewOverlayControl members.
    Public Properties
     NameDescription
     Property Indicates a move handle should be attached to allow the control to be moved around over the map.
     Property Indicates that left and right resize handles should be attached to the control.
     Property Indicates that top and bottom resize handles should be attached to the control.
     Property The control to place over the MapView.
     Property The initial horizontal position of the control as a percent. Can be from 0 (left edge), to 1 (right edge).
     Property The initial vertical position of the control as a percent. Can be from 0 (top edge), to 1 (bottom edge).
     Property When the window is resized the distance from the edge is maintained relative to a corner of the map.
    Top
