ArcGIS.Desktop.Mapping Namespace / MapViewOverlayControl Class
Properties Methods Events
    MapViewOverlayControl Class Members
    The following tables list the members exposed by MapViewOverlayControl.
    Public Constructors
     NameDescription
    Public Constructor Sets the properties for IMapViewOverlayControl.
    Top
    Public Properties
     NameDescription
    Public Property Indicates a move handle should be attached to allow the control to be moved around over the map.
    Public Property Indicates that left and right resize handles should be attached to the control.
    Public Property Indicates that top and bottom resize handles should be attached to the control.
    Public Property The control to place over the MapView.
    Public Property Indicates a move handle should be usable behind any area of the control that is not hit test visible.
    Public Property The initial horizontal position of the control as a percent. Can be from 0 (left edge), to 1 (right edge).
    Public Property The initial vertical position of the control as a percent. Can be from 0 (top edge), to 1 (bottom edge).
    Public Property Indicates that only corner resize handles should be attached to the control when vertical and horizontal resize is allowed.
    Public Property The margin to maintain from the view border when moving the overlay.
    Public Property When the window is resized the distance from the edge is maintained relative to the top left or bottom right corner of the map.
    Top
    Public Methods
     NameDescription
    Public Method Used to invoke a PositionChanged.
    Top
    Protected Methods
     NameDescription
    Protected Method Used to invoke a PropertyChanged.
    Top
    Public Events
     NameDescription
    Public Event Occurs when the position or relative position to the MapView is changed.
    Public Event Occurs when a property is changed.
    Top
