ArcGIS.Core.Data Namespace / AttributeRuleDefinition Class / GetExcludeFromClientEvaluation Method
    Gets if the rule is to be excluded from client evaluation - that is the rule will NOT be evaluated by the application or client locally before applying the edits to the workspace. Instead the rule will only be evaluated once edits are applied. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetExcludeFromClientEvaluation() As Boolean
    public bool GetExcludeFromClientEvaluation()
    Return Value
    A value indicating if the rule is to be excluded from client evaluation.
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    A geodatabase-related exception has occurred.
    Remarks
    Not all clients have the capability to run all of the available rules so authors can exclude certain rules from client evaluation. This parameter is not applicable for validation rule or calculation rule types if the batch parameter value is set.
    Requirements
    ArcGIS Pro version: 3.2 or higher.
