ArcGIS.Core.Data Namespace / AttributeRuleDefinition Class / GetFieldName Method
    GetFieldName Method
    Gets the name of the field to which this rule will be applied. An empty string is returned if no field is specified. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public string GetFieldName()
    Public Function GetFieldName() As String
    Return Value
    The field name.
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    A geodatabase-related exception has occurred.
    Remarks
    This only applies if the rule type is Calculation.
    Requirements
    ArcGIS Pro version: 3.2 or higher.
