Return Value
The editability flag for the attribute rule field.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run |
| ArcGIS.Core.Data.Exceptions.GeodatabaseException | A geodatabase-related exception has occurred. |
// Must be called within QueuedTask.Run
void GetAttributeRules(Geodatabase geodatabase, string tableName)
using (TableDefinition tableDefinition = geodatabase.GetDefinition<TableDefinition>(tableName))
// Get all attribute rule types
IReadOnlyList<AttributeRuleDefinition> ruleDefinitions = tableDefinition.GetAttributeRules();
// Iterate rule definitions
foreach (AttributeRuleDefinition ruleDefinition in ruleDefinitions)
AttributeRuleType ruleType = ruleDefinition.GetAttributeRuleType();
string ruleDescription = ruleDefinition.GetDescription();
bool isAttributeFieldEditable = ruleDefinition.GetIsFieldEditable();
string arcadeVersionToSupportRule = ruleDefinition.GetMinimumArcadeVersion();
int ruleEvaluationOrder = ruleDefinition.GetEvaluationOrder();
AttributeRuleTriggers triggeringEvents = ruleDefinition.GetTriggeringEvents();
string scriptExpression = ruleDefinition.GetScriptExpression();
// More properties ...
