ArcGIS.Core.Data Namespace / AttributeRuleDefinition Class / GetSubtype Method
    GetSubtype Method
    Gets the subtype to which this rule will be applied, if the dataset has subtypes. />. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetSubtype() As Subtype
    public Subtype GetSubtype()
    Return Value
    A Subtype or null if there is no subtype defined for the attribute rule.
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    A geodatabase-related exception has occurred.
    Requirements
    ArcGIS Pro version: 3.2 or higher.
