ArcGIS.Core.Data Namespace / AttributeRuleDefinition Class / GetTags Method
    GetTags Method
    Gets the set of tags for the rule. Mutliple tags are returned as a semicolon delimited string. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetTags() As IReadOnlyList(Of String)
    public IReadOnlyList<string> GetTags()
    Return Value
    A ReadOnlyList of string.
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    A geodatabase-related exception has occurred.
    Remarks
    Tags can be used to identify the rule (for searching and indexing). If no tags are assigned an empty list is returned.
    Requirements
    ArcGIS Pro version: 3.2 or higher.
