ArcGIS.Core.Data Namespace / FeatureDataset Class / GetDefinition Method / GetDefinition() Method
Example
    Gets the FeatureDatasetDefinition of this dataset. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Shadows Function GetDefinition() As FeatureDatasetDefinition
    public new FeatureDatasetDefinition GetDefinition()
    Return Value
    The FeatureDatasetDefinition of this dataset.
    Exceptions
    ExceptionDescription
    This dataset does not have a valid definition.
    A geodatabase-related exception has occurred.
    Example
    Iterate datasets inside a feature dataset
      // Must be called within QueuedTask.Run
      void IterateDatasetsFromAFeatureDataset(Geodatabase geodatabase, string featureDatasetName = "City", string featureClassInFeatureDataset = "Buildings")
        // Open a feature dataset
        using (FeatureDataset cityFeatureDataset = geodatabase.OpenDataset<FeatureDataset>(featureDatasetName))
          // Get a feature class definition from a feature dataset
          FeatureClassDefinition buildingsFeatureClassDefinition = cityFeatureDataset.GetDefinition<FeatureClassDefinition>(featureClassInFeatureDataset);
          // Iterate dataset definition
          IReadOnlyList<FeatureClassDefinition> cityFeatureClassDefinitions = cityFeatureDataset.GetDefinitions<FeatureClassDefinition>();
          foreach (FeatureClassDefinition cityFeatureClassDefinition in cityFeatureClassDefinitions)
            // Use feature class definition ...
    Requirements
    ArcGIS Pro version: 3.2 or higher.
