ArcGIS.Core.Data Namespace / SQLSyntax Class / Format Method / Format(DateTime,SQLDateTimeType) Method
The value to format.
The type of formatting to perform.
    Formats the dateTime value into a literal string in the format specified by dateTimeType. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function Format( _
       ByVal dateTime As Date, _
       ByVal dateTimeType As SQLDateTimeType _
    ) As String
    Parameters
    dateTime
    dateTimeType
    Return Value
    The formatted DateTime literal string.
    Exceptions
    ExceptionDescription
    dateTimeType is not a field of SQLDateTimeType.
    A geodatabase-related exception has occurred.
    Requirements
    ArcGIS Pro version: 3.2 or higher.
