ArcGIS.Core.Data.Analyst3D Namespace / LasDataset Class / GetName Method
    GetName Method (LasDataset)
    Gets the dataset's name. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Shadows Function GetName() As String
    public new string GetName()
    Return Value
    The dataset's name.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Requirements
    ArcGIS Pro version: 3.2 or higher.
