ArcGIS.Core.Data.Analyst3D Namespace / LasDataset Class / GetPointByID Method
    GetPointByID Method
    Overload List
    OverloadDescription
    Gets the point specified by the file index and point ID. This method must be called on the MCT. Use QueuedTask.Run.
    Gets the points specified by the point ID. Because the LAS dataset can reference multiple LAS files, more than one point with the specified point ID can be found. If a geometry is specified, then only this spatial area is searched. This method must be called on the MCT. Use QueuedTask.Run.
    Requirements
    ArcGIS Pro version: 3.2 or higher.
